Re: 1979 Honda Express II NA50 Starter help!
Jack Rutherford /
I had one where someone had taken apart the engine and didn’t replace the starter arm. I forget what was wrong with the engine on the lime express. It worked and then it didn’t. The starter arm catches the sprocket and allows you to wind up the spring. It must have become misaligned with the sprocket. Probably due to a missing washer on the sprocket shaft. I think I have a post on it here. I’ll look.
There’s also a spring under the starter arm. If that comes off, it may cause alignment issues. (edited)
