Derbi Rd-50/C-5 fork oil volume?
Anybody know how much oil the forks of a derbi rd50 take?
Re: Derbi Rd-50/C-5 fork oil volume?
The difference of compressed length and full extened length of the fork from the top . Maybe less just a bit . ;)
That would be tough to measure as far as volume. Maybe submerge the bottom of the fork leg and succc it up like a syringe?
Now I have to pee.
> Brandon Weiss (Detective brandon to you) Wrote:
> fork
Can't just pull the fork cap and pour ?
> > fork
For some reason I'm just not following... Fill it with more than enough, then pop the drain an measure what comes out from fully extended to fully compressed position?
Sorry . I should have been more clear .
With a tape measure , measure the difference between fully extended and fully compressed , say 3" . Then , fill to 3" from the top of each leg when they are extended , hanging in the triple tree . ;)
> enough,
I still don't understand how you would know how much 3" of hypothetical travel would convert into fluid ounces, because there's no way to measure height or fluid level inside the forks when they're assembled
Once you have the measurement , with the forks mounted and extended , with the caps removed .
Just fill each leg until the fluid level reaches the difference distance ( ie : 3" ) from the top of each leg .
It doesn't matter how many ounces that takes .
If you have to know how many ounces that^ takes , do what's described , drain the leg and measure the contents in fluid ounces . ;)
Dirty30 Dillon /
The way being described is the common practice in dirtbike fork. Just use a probe down into the tubes as a dipstick
