Replacement wire
I've been reading past threads of people rewiring their rides.My Vespa uses AWG 18. Now going to do another one and I'm seeing heat resistant, flexible, silicone, it goes on. Am I reading too much or should I stick to the wire I get from the parts store?
Re: Replacement wire
♣Slew Foot♣ /
Its mopeds use phone wires if you want just check the resistance factor of the actual harness. If the bike had a cerramic resistor in the tail you might have to ditch it if it don't work. No harm no foul ...
yea I use all kinds of whatever, i've definitely wired with speaker wire just cuz the coupled +/- wire is easy & simple. I save random wires torn outta other bikes, or often just reqire with the same original wires, only simplified
♣Slew Foot♣ /
I will reuse computer power supplies harnesses
