As stated above. You need to clean the carb. Instead of wasting time trying to order the right ones, you could have cleaned the carb. They're pretty simple once you open them up. There's plenty of diagrams to look at as well. A carb doesn't work without spark. So I'd get spark first and go from there.
Truthfully, just get a Puch. So much easier. But as also stated above, if you can't or won't clean a carb, mopeds aren't for you. I'd stick with it and spend as little as possible.
