Rusty Wheels
What’s the best way to remove rust from chrome wheels ? Thanks
Re: Rusty Wheels
Sos pad ..or pot scrubber steel wool to start then polish if very much ..
Re: Rusty Wheels
Loosely wad up a small ball of aluminum foil, dip in water and scrub. Rust disappears like magic.
Re: Rusty Wheels
Forgo anything abrasive like steel wool, sand paper etc. Aluminum foil works well because it's softer than nickel (chrome). Forgo water when using foil and use vinegar. Vinegar will dissolve the rust while the foil breaks it loose.
Re: Rusty Wheels
you could try muriatic acid (HCl) and aluminum foil
JUST KIDDING!!! don't do that hahaha
I use penetrating oil (PB blaster or whatever) and aluminum foil, it does a good job breaking down the buildup and also the oil prevents it from rusting again quickly.
steel wool, sand paper and even scotch brite pads are all more abrasive than chrome and can scratch it, leaving it looking duller
if you're going for a real nice final finish, try some wadding (Nevr dull), it's not expensive and a little bit goes a long way. it's pretty nuts, it works very well.
Re: Rusty Wheels
Believe it or not , good old mud does a pretty good job of removing rust on wheels .
Get a handful of dirt , add a bit of water to the point of a nice thick mud .
Apply it and work it with your fingers . Then rinse .
Re: Rusty Wheels
rusty is a realative term. little rusty a few spots lotsa good chrome, rusty all over but kinda shiny, saveable, or mostly rusty. removing goes from 4O (OOOO) steel wool n rubbing compound to wire wheel on drill and steel wool/rubbing compound.
Re: Rusty Wheels
I’ll try the foil ,vinegar and blaster,so far I’ve used vinegar ,600 wet/dry sandpaper,it not dulling or scratching the surface but sure is a slow process .The wheels overall aren’t bad just heavy in spots.Has anyone used Evaporust ?Thanks I’ll keep piddling away.
Re: Rusty Wheels
EH 📣FCC of the QCB /
Huh....did not know about aluminum foil.
Re: Rusty Wheels
Hey , you likely didn't know about mud either . LOL
Re: Rusty Wheels
You might lose a little shine but i just cleaned a rusty pair with sos pads ..if they are very bad they are going to show pitted plays anyway so loosing a little shine won't be noticable .
Re: Rusty Wheels
I didn’t, but I would use al-foil over a hand full of mud.....little easier to manage.
Re: Rusty Wheels
Evaporust is great for soaking rusted parts in, or filling a rusty gas tank with. Never tried it with scrubbing rims, but I use foil and water exclusively, and it works great, & is super easy & fast.(vinegar is ok too, but may flash rust on ya)
Re: Rusty Wheels
> easier to manage.
I can see that . When the aluminum foil isn't doing what you want , try the mud .
It may not do what you want either , but , then you'll know . ;)
A little secret : Mud , in the right consistency , is the mother of rubbing compound ( which also does a good job of removing rust ) . (edited)
Re: Rusty Wheels
I jut dipped my rusty chrome rim and some other rusty parts in Evaporust. Let them in around 20 hours .I couldn’t believe the results , it removed all the rust ! I buffed it with some fine steel wool and the parts look fantastic! It’s around $25 a gallon but each gallon removes one half pound of rust so you can keep using it . I’ve got more parts soaking right now , amazing stuff !
Re: Rusty Wheels
Something else to consider for rust removal : Oxalic Acid .
It does a great job and it's cheap . ;)
Use the search :
https://mopedarmy.com/forums/search.php?6,search=oxalic,author=,page=1,match_type=ALL,match_dates=0,match_forum=ALL,match_threads=0
Re: Rusty Wheels
I "used" up all my evaporust trying to derust a tank. it turned out it was so rusty that without the rust there, all that was left was holes. made a real nasty mess of the floor and i havent replaced the gallon
Re: Rusty Wheels
> Use the search :
I bought a ten pound bag of Oxalic Acid powder on Amazon pretty cheap. I haven’t used any yet. I’ve got a frame and a few rims & rando parts to soak. Still haven’t made a soaking tub yet.
Any idea what the mixing ratio to water is? IIRC it’s about 3 tablespoons/gallon.
Re: Rusty Wheels
> tablespoons/gallon.
Recommended mix ratio : 12 ounces to 1 gallon of water .
I used 12 ounces to 2 gallons of water and left things soak until I was satisfied ( a couple days for my Simplex tank , which was not badly rusted ) .
Re: Rusty Wheels
> P D Wrote:
> I
> > tablespoons/gallon.
> rusted ) .
12 ounces by weight, or liquid measure? If I remember your thread, Didn’t you use the liquid stuff from the hardware store? It’s not as concentrated as the powder, i think. Can’t remember atm, but 6 ounces/gallon seems like a lot, if powdered. (edited)
Re: Rusty Wheels
Back to rusty wheels, and I’m starting on a grubby Ciao rim tonight. I didn’t think this one would clean up...
But after about five minutes scrubbing a section with foil & water...
It looks like it’ll clean up pretty decent, considering.
Re: Rusty Wheels
36 minutes later, all done. After a quick final scrub with soap & water in the bathtub (while the wife is at work). Here’s results:
It’s not perfect, and I could have spent a little more time around the nipples, but considering what I started with, it’ll do.
And only about 15 cents worth of foil.
Re: Rusty Wheels
That looks really good ,I’ll give it a try. Even if we never get this bike running at least it will look impressive . Thanks
Re: Rusty Wheels
I’ve never tried foil, I’ll have to give it a shot. I’ve used Brasso liquid with 0000 steel wool for heavy stuff before, works well. And I will 2nd using NeverDull, love that stuff and works well for cleaning spokes, if you have the patience for such a tedious task.
Re: Rusty Wheels
Your right about the spokes,I’m thinking about getting a spoke tool and clean one at a time then put them back in. That makes for a long winter
Re: Rusty Wheels
If you have never spoked a wheel you.might want to clean them as they are..if you don't get them torqued back right you could end up with some really wobbly wheels .. ..
Re: Rusty Wheels
Thanks for the info , that will definitely make me take the old school route.
Re: Rusty Wheels
♣Slew Foot♣ /
Yeah you don't you don't want to ever mess with those spokes unless you have to it is an art and a science to re-lace the hubs and you need a truing stand a good ear and calipers and an insanely large amount attention to detail and patience
Re: Rusty Wheels
I looked up removing spokes on you tube and saw a pro doing it .Id have to take it to a bicycle shop and that would put this $300 bargain bike easily over the $1000 mark,
dirty spokes aren’t all that bad after all .
Re: Rusty Wheels
If they are just/simply dirty , clean them .
Cheap , but, labor intensive : SOS pads .
More expensive , but, much less labor intensive : S100 Total Cycle Cleaner .
