I'm doing a ZA50 rebuild, but I can not locate shims to properly tolerance the trans side. Can anyone recommend a good source?
Yeah, they show them, but when you pick the part, there are no sizes available. :-(
Post the sizes you need in B/S forum and cross your fingers. Sometimes people post shim lots for sale there too.
Click here for shims.
Here's the site that Den tried to link to :
Thanks for repairing the link.
Any time . :)
> Den 23 Wrote:
> > https://www.mcmaster.com/catalog/125/3366
I live 10 minutes away from McMaster Carr and will call stuff from there all the time,
Very few of the metric shims are exactly like stock ones though thickness is correct the OD and ID are not the same, some don’t work some are close enough to work,
I’ve used some SAE ones from there in thousands of inch that are closer to OD and ID,
Thanks folks. I'll do some poking around and see what I can find.
