Re: Piping exhaust outside.
Rebel Moby /
Dumping a exit that is less than 1 inch into a pipe that is 2 inch will not measurably change the "atmospheric pressure at the end of the exhaust" as much as a device creating a partial vacuum in a collector box.... just saying...
> Brad William Wrote:
> For tuning's sake you probably don't want to mess with any big changes
> in atmospheric pressure at the end of the exhaust. A two stroke is
> going to be more sensitive to this than a four. So just extending the
> pipe out the window with a hose connected to the exhaust is going to add
> back-pressure.
> When I've run a two stroke indoors I've set a good sized cardboard box,
> , opened at one end, that end facing the exhaust, plug a shop vac hose
> into the other end of the box, and run a hose from the shop vac's
> exhaust out a window. 100 percent effective without altering the tuning
> of the pipe.
