Titled if your state needs it? Is it complete, you really have to go look, check inside of tank for rust. If all there and has any needed paperwork offer 250-275ish. Look out for missing parts, hacked wiring, missing/rigged up switch's, any bicycle parts grafted on, no id plate, no paperwork, spray bombed black, vauge backstory. On the other hand, many people make the mistake of leaving the petcock on all winter or for a yr or two without draining the tank and running the carb dry, causing it to varnish up. You really have to go take a look. (edited)
