Re: Piaggio - Bravo - Moped flywheel issue
cheetahchrome . /
I have found that if you had you coils off, when you put them back they do have a small amount of play between the screw and the hole in the coil. Loosen the screws on the coils and press them inward so that they cant be rubbing on the flywheel.
Try the wheel again
