Re: Piaggio - Bravo - Moped flywheel issue
pat splat /
whatcha mean by stiff? once lined up w woodruff and bolted down(put the spacer/clutch/variator on and crank on the nut). it should spin smooth and not rub case nor those wires on your points, why r there 2?
the kill wire should be split off your coil.
when u spin dont let your finger get caught on those case posts, i hate that.
