Re: No compression
Pops Peds /
> Tim Doll Wrote:
> Thank you for the info , I’m having another senior moment .Im waiting on
> a clutch tension spring because I found out mine didn’t have one when I
> bought it luckily someone on this site had one.I just can seem to
> understand how by turning the flywheel the piston is not moving in the
> cylinder ,why was the dowel in the cylinder moving. I know your 100%
> correct
If you turned the flywheel and the dowel moved then your piston moved ..the pedals won't turn the flywheel unless you pull the decompression lever to engage the clutch to turn the motor..without pulling the decompression lever you are in pedal mode and the motor does not turn
