Re: No compression
Tim Doll /
Thank you for the info , I’m having another senior moment .Im waiting on a clutch tension spring because I found out mine didn’t have one when I bought it luckily someone on this site had one.I just can seem to understand how by turning the flywheel the piston is not moving in the cylinder ,why was the dowel in the cylinder moving. I know your 100% correct
