Thanks again ,I’ll give that a try I also just noticed a wire on the front brake that’s hooked up to the break light is broken and I took the black cover off to check points and timing and a wire for the rear break light is also broken is it possible that it will not run because of this issue? I still have spark but it will only fire once or twice
