Re: Bing carb tool
Tim Doll /
Thank you again .do I just use a spray cleaner or fine sandpaper.Ill check the grounds for sure.When I got the bike the hand lever for the clutch didn’t feel right,it was real sponges and wouldn’t release on it’s own I took the clutch cover off cleaned up the oil,took out the threaded pin ,the bushing was there but the tension spring was missing. The moped parts stores didn’t have one but I posted on this site and got one which is on the wayI don’t know if this has anything to do about it running but it will sure make it easier to work on. Thanks
