Re: New Engine to replace Sachs 504
Daniel '' /
This is not that foxi. This the the gt sport also known as the Sparta foxi. You’re hosed unless you can do some welding. Even if you manage to hack some brackets onto the frame for a Lifan, the frame is 2 pieces and will crack from normal use with the 504. Any more power is sure to tear that schnitzel frame apart.
