Hi, not really done much with it of recent, fired it up, switched lights on and something came loose in coil/points area and cut out, any suggestions what it could be before I get chance to have a look?
What is the prize for guessing right ?
Hurry up and have that look . The suspense is killing us . ;)
might have to do something w u switching lights... the garellis ive seen have external ignition ground(look up on myrons page) spark works off stop light circuit, brake switches, reading time. or it could just be your kill switch, or a loose wire, etc.
Update,sparks there, nothing loose in points area, took head off, piston rings ok, still not firing and occasional loose noise still apparent?
Fuels present in the carb, any ideas what to look at next, many thanks.
Plugs is wet with fuel and the noise is mettalic.
spark yes or no? as far as the noise, id take a look under your flywheel, good time to service points. maybe a bolt came loose and is tossing around. you'll need appropriate flywheel puller 19x1 and as always change out that crank seal too.
