Completely tore down my C102 for a full resto. I was excited to start motor assembly until I spent six hours on an annoying issue.
Here’s the problem. Shift drum and gears are (I thought) correctly placed. I can easily rotate and cycle through the 3 gears and neutral when the left case is face up. Kickstart spindle is working as intended.
I can lay the right case on top and seat. Gears spin fine, shift drum works well. Kick spindle works.
I then tighten all case bolts down and the gears lock up. I’ve opened and closed the case 10 times without isolating the issue.
Any pointers? I’m stuck. It’s a 64, Honda C102.
