Re: Do i need a new reed valve for qt50
Pops Peds /
> Nick Haber Wrote:
> If you have an airleak in your intake, the reeds aren't the issue. The
> seal between the reedblock and the case is the issue (or seal between
> the carb and intake). New gaskets should fix it. While you're in there I
> would slap on some new performance reeds anyways:
> https://www.treatland.tv/boyesen-dual-stage-reeds-for-YAMAHA-QT50-PW50-YT-p/boyesen-yamaha-qt50-reeds-674.htm
I understand it is gasket problem but 35 year old reeds wearing out was actually the reason i asked,plus not being familiar with them wanted input on maybe newer technology that would give better performance.i guess i should say since i am replacing the gaskets should the reeds being that old be replaced and are there better options...thanks for the reply (edited)
