Re: Do i need a new reed valve for qt50
Nick MBC /
If you have an airleak in your intake, the reeds aren't the issue. The seal between the reedblock and the case is the issue (or seal between the carb and intake). New gaskets should fix it. While you're in there I would slap on some new performance reeds anyways: https://www.treatland.tv/boyesen-dual-stage-reeds-for-YAMAHA-QT50-PW50-YT-p/boyesen-yamaha-qt50-reeds-674.htm
