82 Honda Express SR 50 starter removal??
Danny Warner /
so... apparently have the motor and drive have to be removed to have enough room for the starter to drop out? i have the 2 bolts out and it moves about 1/4 inch but hits the backside of the housing where the kickstart mechanism and pulleys are... ugh,thought this would be a easy job! hahaha any input would be appreciated
Re: 82 Honda Express SR 50 starter removal??
Jack Rutherford /
I think just the stator cover needs to come off and maybe the rear fender if you have it still. My buddy did this a week or so ago and I was there.
I suspect it's like the NU50M. Remove the wire and bolts. If I recall, it gets tilted and removed out the back side. But there was only ONE position where it could be removed. Try every conceivable angle and rotational position.
Mopeds for ever MFE /
To remove an electric starter from a honda nu50m deluxe you must take off the rear off to gain clearance otherwise it will not come off.
"you must take off the rear off"
Please explain.
Danny Warner /
i havent messed with it for a few days, ima get on it this week though. funny cause the 2 bolts are easy to get to, the wires are easy to get to, then the starter is another story, i have the scooter on a bench now, so maybe im missing something that now i may be able to see..., i can try the every angle possible approach !
