Moby crank case
So in getting the seals and bearings out I put a dimple in the inside of the case. Should I just sand this down a bit and let it go or am I screwed in getting a good deal going forward.
Thanks
Re: Moby crank case
smooth it out, you should be fine
Re: Moby crank case
Indeed - make it smooth and it will be okay
