Re: Need to buy connectors for a switch - Please Advise.
live ɘvil /
> Brad William Wrote:
> > live ɘvil Wrote:
> > > Dirty30 Dillon Wrote:
> > > Those are solder terminals, there are no quick discos for that male
> > leg.
> > > If you're melting plastic, then you need to spend less time with the
> > > iron on there
> > Hes not using any flux
> ...and use a screaming hot iron. Get on and off the solder joint FAST.
> if all else fails use foresepts on the metal as a heat sink between the
> solder and the plastic parts.
True that^^
When you decide to get flux do NOT use acid core. Must be safe for copper wiring. (edited)
