Re: Need to buy connectors for a switch - Please Advise.
Brad William /
> live ɘvil Wrote:
> > Dirty30 Dillon Wrote:
> > Those are solder terminals, there are no quick discos for that male
> leg.
> > If you're melting plastic, then you need to spend less time with the
> > iron on there
> Hes not using any flux
...and use a screaming hot iron. Get on and off the solder joint FAST. if all else fails use foresepts on the metal as a heat sink between the solder and the plastic parts.
