Re: Need to buy connectors for a switch - Please Advise.
Simon Belmont /
Hey I solved this!
I found an extra block with wires laying around, took out 3 wires with metal connectors from it - yes they are 2.8mm, all I had to do was squeeze connectors just a little to make a tight fit, attach them onto the pins, then slide heat-shrink tubing on top so the little terminals don't make contact to each other and it works perfectly, shrinking the tubing will make tight connection to the wire.
