Re: Need to buy connectors for a switch - Please Advise.
Dirty30 Dillon /
So I don't truly understand why you stripped away the plastic portion, but in that case you know that a micro-crimp termination would fit, although the crimo tool is much more expensive.
The smallest one in that set is 2.8mm, so measure the terminal you have and compare? Whether it slides over and whether it holds on, are two different things.
