back wheel hardly spinning and no power
Christian Barrit /
Hi Moped Army.
I have a problem with my puch maxi k. I am currently trying to renovate it and make it run but there seems to be a bit of a problem. I can assemble the back wheel with spacers and all that. i bought an aftermarket back brake which doesn't seem to be working that well. When i tighten the wheel and adjust my wheel, the wheel won't spin or anything and the chain is also very tight. When i loosen up the bolt on both sides of the back wheel, it can spin but the bolts are nearly not even on. I am currently thinking a solution plan, and i think that i need to adjust my brake in some kind or way or i need to do something to the bearings.
My second problem with the bike is when i actually finished building my bike and was going for a ride, it would not run properly. It seems like the bike was making a lot of power but when i had it on full throttle, but i just couldn't take off.
I really want my bike assembled the right way, and i hope someone can help me.
Thanks in advance.
