Re: Honda Express only runs well without air filter.
Mike Kirn /
> Dan Church Wrote:
> The stock airbox has no filter inside, and
> apparently they are no longer available.
On that air box assembly, should there be anything else inside the box other than the foam filter? I had an Express with the same symptoms. Turns out there was supposed to be little frame in the airbox holding the filter a short distance from the carb intake. Air was to pass over the entire rear side of the filter, exit the entire front side of the filter and then be drawn into the carb. (there is a short distance from the filter to the carb - 1/2", 1", ?, I don't remember). Without this little frame to maintain that space between the exit side of the filter and the carb, the increase in air velocity as engine speed increased would draw the filter up tightly against the carb. At this point, instead of air coming across the full face of the filter (what, 3" X 4"?), you had air coming across only at the opening of the carb (what, 1-1/4"?) - not enough air. I made a little frame device out of a coat hanger and solved my problem. p.s. look up the airbox assembly online and see if you are missing anything. (edited)
  Honda Express only runs well without air filter.Topic by: Dan Church Dan Church 11/23/19 09:22AM
  Re: Honda Express only runs well without air filter.Re: Moped Lar Moped Lar 11/23/19 10:09AM
  Re: Honda Express only runs well without air filter.Re: Dan Church Dan Church 11/23/19 10:14AM
  Re: Honda Express only runs well without air filter.Re: Moped Lar Moped Lar 11/23/19 10:29AM
  Re: Honda Express only runs well without air filter.Re: Dan Church Dan Church 11/23/19 10:42AM
  Re: Honda Express only runs well without air filter.Re: Moped Lar Moped Lar 11/23/19 10:47AM
  Re: Honda Express only runs well without air filter.Re: Mike Kirn Mike Kirn 11/23/19 04:53PM
  Re: Honda Express only runs well without air filter.Re: Dan Church Dan Church 11/23/19 06:35PM
  Re: Honda Express only runs well without air filter.Re: live ɘvil live ɘvil 11/23/19 11:07AM
  Re: Honda Express only runs well without air filter.Re: Dan Church Dan Church 11/23/19 11:10AM
  Re: Honda Express only runs well without air filter.Re: live ɘvil live ɘvil 11/23/19 06:44PM
  Re: Honda Express only runs well without air filter.Re: live ɘvil live ɘvil 11/23/19 06:51PM
  Re: Honda Express only runs well without air filter.Re: Stephen Keller Stephen Keller 11/23/19 06:54PM
  Re: Honda Express only runs well without air filter.Re: Moped Lar Moped Lar 11/23/19 11:29AM
  Re: Honda Express only runs well without air filter.Re: Dan Church Dan Church 11/23/19 11:37AM
  Re: Honda Express only runs well without air filter.Re: Stephen Keller Stephen Keller 11/23/19 06:34PM
