The bronze bearing/bushing at the shaft end. Just the bearing. Not the crank. (edited)
Buy one used and use bushing adhesive to connect it
If it’s a stock used crank I may have one if it’s the smaller size for sure I have one but the larger size I’m not sure
This is a bronze bearing that supports rotating parts. It wears out. It's not available for replacement?
I've never found any.
Yeah those came in 2 sizes. Have you measured the original?
It is called a clutch basket bushing and comes in 9.6mm and 10.2mm .
No , you can not buy one off the shelf.
Call treats and see if they will have one from a damaged crank.
I doubt it . It would be almost impossible to press one off without damaging it.
Get a new crank and be done.
Small ones are available on eBay
Do you have a link?
