Anyone else using LED headlight on their moped instead of incandescent bulb?
If so do you prefer it over the incandescent? (edited)
I have a LED headlight that is much better that a incandescent but I have 12v to help it.
pretty often requires at least a rectifier to work right, Diodes by their nature don't like reverse current.
But you can do it.
Typically a similar size LED will be brighter at less range, this obviously depends enormously on specifics but comparing a budget off-the sheld LED "Headlight" vs like a stock moped CEV bucket
Ask that El Pollo nut job over in gen.
