U got that from the YouTube video!
Rocco’s tips: once you get the first clip off you have about a 1/4” of play in the variator. Push it all the way back against the engine this makes removing the last clip easy becuase you can get a good grip on it.
To remove the washer use a pair of picks:
https://www.parktool.com/product/utility-pick-set-up-set
when you spread the 15mm clip pull the variator towards you and the clip will slip off with the variator. (edited)
