carburetor
what kind of carburetor go in a 1978 vespa piaggio bravo moped
Re: carburetor
Sha 12/10? I'd put a 12/12 or 13/13 though.
Re: carburetor
james horvath /
ok where on line do i get one
Re: carburetor
james horvath /
Re: carburetor
Double Trouble Dan /
Re: carburetor
james horvath /
this one doesnt have the choke on it
Re: carburetor
Sitting here thinking about it I have a stock one you can get because I replaced mine with a 13/13 when I kitted it. Or if you want a 13/13 I used this one on my bravo.
https://www.doscycles.com/products/dellorto-sha-13-13-for-vespa-mopeds
^^^^ that price is shipped also
Re: carburetor
james horvath /
not sure it doesnt look like the one on my moped now the choke is different
Re: carburetor
Dirty30 Dillon /
It's a Dellorto SHA, in either 12.12, or 13.13.
choke style shouldn't really matter, but you could get this one as well.
https://www.treatland.tv/dellorto-SHA-13-13-carburetor-ciao-style-choke-p/dellorto-sha-13.13-carb-2046.htm
You will need a corresponding filter and to jet the carb properly as well.
Re: carburetor
yea the choke on the dos one works the same way it's just got a lil hole so you can use it from the side of the bike like on a grande or bravo, vs the simplified little lever tab for the ciaos. but the dos on you can use the same way as the other. thatsytle does both, the lil metal sheet tab only works the ciao way.
I've been meaning to get one for a bat
