So I am thinking I need to replace my condenser on my Honda NC50. I have yet to order from Treatland and actually look at the part. It looks like a pretty simple install. The only part I am unsure of is how to ground the coil. How do you do this?
honda nc50 ignition coil grounding
Re: honda nc50 ignition coil grounding
if its like a hobbit, it grounds thru the bolt holes. i just had a no spark on a honda, came back to life after cleaning the points a few times.
Honda NC50 1980
I am going to clean and set the points.
Does it sound like a condenser problem too?
Sounds like a carb problem to me.
Hmm, I just put a new Dollorto SHA Carb on. It starts right up no choke.
Picture please. I have a 81 that I've been thinking of a carb upgrade.
High tension coil is under seat and was originally sitting in a foam tray. Ground wire runs to it. Condensor is integrated with coil. (edited)
