I pulled the cover off the clutch side of the engine see how the clutch was looking. Things looked good but after reassembly the engine will so in the wheels with it on the center stand but when back on the ground any wheel resistance kills it. If I rev it a bit it almost feels like a lurch once in a while but not enough to get moving. There were some thin washers that fell out. I put two larger ones back on the pedal shaft and the tiny one on the middle shaft. There didn’t appear to washers on the clutch shaft.
Any ideas..?
Thanks. I seem to remember reading about someone with a similar issue a while back but searching wasn’t coming up with anything.
