Cam puller
Is there a down side to using a 2 arm puller rather than a screw in type?
Ken
Re: Cam puller
Cam for what?
Re: Cam puller
Don’t even try to use 2 arm puller on the timing cam. You’ll screw up the cam and god knows what else.
Re: Cam puller
Ooooo-Kay!
Re: Cam puller
The one to get got Mobys with stock points ignition AND clutch cover
https://www.treatland.tv/24mm-x-1mm-26mm-x-1mm-puller-for-honda-mbk-p/24x1-26x1-honda-mbk-puller.htm
If you have a CDI then you need this one (will need a 24mm for the clutch though)
https://www.treatland.tv/19mm-x-1mm-flywheel-magneto-puller-p/19mm-flywheel-puller.htm
Re: Cam puller
On a stock 78 50V my guess is no CDI?
If I pull the ignition should I replace the points or any of the coils or condenser (its on the back of the plate)? Or is that a big ol' pain?
Ken
Re: Cam puller
Its one of those deals where saving a couple bucks will cost you ten fold in the end.^^
