Points arcing
Drake Abrahamsson /
Just installed a new condenser and points. It’s pitch black out thanks to the daylights saving adjustment and I looked into the points and they’re arcing a little bit. I doubt I could see it in the daylight (emphasis on pitch black from previous sentence). I could see the arcing quite clear in daylight with the last set of points/condenser. Should I have absolutely zero arcing or should I expect a little bit? Thanks!
Re: Points arcing
Should be a little bit.
Re: Points arcing
Some arcing is normal, if it is excessive make sure you do not have the external coil wired backwards if it has two primary connections: terminal marked as 1 is points; 15 is ground.
Re: Points arcing
♣Slew Foot♣ /
this should be in the first few lines of the wiki...
Re: Points arcing
Richard Eberline /
Points adjusted to tight will arc more. The condenser, your condition of ground wires and components are big factors. The condensers job is to help stop the arcing and pitting of your ignition points. OEM components are always a good choice.
Re: Points arcing
Like Richard says, try another CORRECT condenser. Check gap on the points ,usually fourteen thousandths of an inch is good, that's .014".
Re: Points arcing
Drake Abrahamsson /
I got this one. https://www.treatland.tv/puch-moped-condenser-solder-type-p/puch-condenser-solder.htm
I got the Bosch points, not the cheap ones
In the daylight there is no arcing to be seen- before the replacement I could easily see long arcs across the points
Re: Points arcing
Drake Abrahamsson /
Thank you! That is good info
