Just installed a new condenser and points. It’s pitch black out thanks to the daylights saving adjustment and I looked into the points and they’re arcing a little bit. I doubt I could see it in the daylight (emphasis on pitch black from previous sentence). I could see the arcing quite clear in daylight with the last set of points/condenser. Should I have absolutely zero arcing or should I expect a little bit? Thanks!
