Will a VM18 fit an e50 between the engine and frame?
Brad William /
This pic is online at Mopeddivision.
"Athena Intake for Puch E50 engines. PHBG carburetors on ZA50 mopeds work with this intake as well."
The pic looks like a vm18 attached. Every pic I've seen of a vm18 on an e50 has it mounted outbound on a long intake.
Will it fit?
Re: Will a VM18 fit an e50 between the engine and frame?
I’m skeptical to say the least. The fact it says it will work in za50 really makes it seem like they’re lying.
Brad William /
What is the athena bolt spread? anyone?
I tig weld and have a lot of aluminum tube around the shop so I'm probably going to attempt to mount the vm18 that i have with a custom fabricated intake. But I'm not impractical. If there's a cast aluminum intake like the one above that's priced (at treats) for 20usd, and will connect my vm18 with my airsal 44mm cylinder I'll put it in my basket in a split second rather than fuk with all that. (edited)
Just make one, those things are terrible and never seal properly.
