Any easy DIY for the 51mm wrench that will fit and get in that tight space?
Thanks,
Ken
Thanks,
Ken
So, if you use an actual 21mm spark plug socket with the flat boarders on the top side then you can use a adjustable wrench to do this. If you use a normal smooth sized deep socket you are in trouble. Lesson learned.
Ken
Cheapest = most effective
> learned.
13/16 socket and open end FTW—this is what I have to use on my GT185
lowest profile setup
Factory spark plug wrench in the Moby tool bag always worked fine for me.
So FYI a 13/16 offset wrench will work with no mods. Whole set harbor Freight for 15 bucks
> me.
Yep.
