bearing Locating Ring
Dan O'Connor /
Question, there is a blurb in the 80-84 puch service manual on page 46 regarding the locating ring installation. Is there some significance to this, and if so I just wanted to check on the upwards orientation (is it referring to "gaps face straight up" relative to the case being on a bench with the drain plug on the bottom against the bench).
NOTE: Assure the locating rings (on crankshaft clutch side main bearings and primary drive, between bearing and seal) have their gaps face straight up.
Re: bearing Locating Ring
Yup that’s how I always do it
