No spark.
1978 Moby I put a new coil on but no spark. New wire and plug as well.
Points next or something else?
Ken
Re: No spark.
Gonna have to do the whole check:
check all ignition wiring from coil, points, condenser, HT coil, plug etc
check for faulty grounded kill switch
clean and polish flywheel points cam
clean and set points
Re: No spark.
Any tutorials on how to work through this
Re: No spark.
So I pedal the bike pretty hard and none of the light go on, but the horn does give a really weak sound if I hit that button. Not sure if this helps the diagnosis.
Ken
Re: No spark.
Start with Fred's Guide
Re: No spark.
Richard Eberline /
Ground issue, clean and clean, no oxidation, rust, oil, grease and paint. Remove flywheel and clean points, rust on internal coil faces and check or replace condenser. Rebel Moby uses a external condenser. I went to a La Parti CDI. Pm me with a mobile #.
Re: No spark.
Diagnosed and put in a new coil. We now have spark. A huge thanks for Rickard Eberline, aka rockettman. He was such a huge help! He is the reason why these groups work.
Ken
