pertinant info, moded unstock cases was never mentioned.
> Ira Bel Wrote:
> 'just wanted to give an update here.
> I finally gave up on the (new) case I was using and crank that I have.
> My guess is that there might be excessive clearance there.
> I reused an old unopened case that I had (that wasn't restricted with a
> steel insert on the inlet like the one I was using) + the 50cc cylinder
> and piston + 13/13 carb + high flow air filter + high flow exhaust.
> It works fine.
> In a week or three I will try to get the 60cc working with yet another
> unrestricted, non-aftermarket, case I have on the shelf.
> In the meantime, the above upgrades already make a pleasant difference.
> I went from anemic performance to reasonable-ish power. The cruise
> speed went from 25 kph to 35 kph. The top speed went from 30 to 40.
> That is fine for my application. I don't need anymore speed.
> I am hoping the 60cc kit give me a little more torque and acceleration.
> Top speed is fine as it is.
> Stay tuned.
