Wondering if anyone has any idea. Bought this moped knowing it didn’t run but that maybe just top end or something. When I spin the vareator side outer part or inner the piston doesn’t move and when I spin the other side the piston moves. Even if I pedal like crazy and I see the clutch side moving in to the belt the other sides just sits there ?? Pulled the vareator off and it looks ok but I bought new clutch pads and new starter clutches for it but I don’t think that’s the issue. I was going to pull the other side off because one person said there is a key way that probably broke but then others say there is no key way. When I put the puller on the right side and just snugged it up it seem to spin both sides.
