1979 puch maxi won’t start
Boris Lantsov /
So I just bought 79 puch maxi that doesn’t start, I checked for spark, it has spark, fuel is old but I’m sure it should at least try to start, took carb apart it’s pretty clean inside.... so I tried to start it with a drill no luck with pedals no luck , even tried to put some fuel in the cylinder and still no start.... any one can guid me in the right direction I can try? When I spin it with a drill it gives out small sparks “picture attached” and it sounds like it has compression when spinning it with out spark plug
