Re: Need Hero Majestic Ankur Service manual
Don Ohio /
If you can get an inline paper-pleated filter on the line, it will take care of the debris as it breaks loose and heads for the banjo filter at the carb. I had the same situation when I bought the 1994 Ankur with only 18 miles.
Get all the varnish out of the float bowl. Anywhere you can use steam safely, you can remove the varnish that way.
