Puch 6 volt voltage regulator wiring question
Dan (high idle) Conway /
Quick question, so i’m blasting out mad RPMs and got the treats regulator same thing as this...
Im trying to find a way to wire up ALL my lights to this?
Puch uses separate coils/ wires for taillight, Headlight and brakelight.
I’ve been blowing taillights but also brake
lights :(
Any ideas anyone?
Re: Puch 6 volt voltage regulator wiring question
Use more than one?
At 35 a pop that’s a pricey way to go.
Anyone got any other ideas?
Haha wtf
Okay you gotta buy Japanese terminals! They call them double split barrels. It’s like adding a wire strip on top of a wire strip or pluging mad ps2 controls in to the same port when you have a game party
Trail tech
Wiring diagram!!!!!
Use the second picture but wire all your accessories to the yellow wire or (“out”) (edited)
Thanks for the reply Rocco-
I ended up just wiring up the taillight and went for a good spin and didn’t blow any bulbs. If I blow a brake light i’m gonna try throwing a 1000uf capacitor in line, someone had good results with a kitted 6 volt E50 maxi and this method.
If I end up having to do this i’ll check back with the results.
♣Slew Foot♣ /
That looks identical to a TOMOS regulator.
12 V. But 6 & 12 V are interchangeable for the most part. Amps and watts are the culprits most 6v bikes don't have a regulator.
Double Trouble Dan /
problem solved.
