Re: 1995 Tomos Targa brakes
♣Slew Foot♣ /
Yeah there should be some Adjusters or there should be a screw that holds the cable onto the brake arm. Sometimes the rear will lock up because the brake arm doesn't have a return spring on it I found that my Tomas from 97 has that problem so I went to the hardware store and I found a 10 lb spring compression and then ran it through the cable between the arm and the fixture to hold the north as a result my Tomas rear wheel doesn't stay locked
