Re: Minarelli v1 external condenser
pat splat /
make sure that wire is tucked inside the flywheel and that it will never rub anything. those two are the same wire, makes it easy to install one on coil and the other to your hot lead. , make sure u ground the body of the condenser to your frame thru the bolt.
