> Kyle Gerber Wrote:
> So an update on my end. Got it running and tops out at 23-24 mph. I'm
> guessing that I can get a bit more speed by messing with the Idle screw
> and float screw?
> It was a clogged muffler that was the culprit for my poor power. To
> unclog the muffler I boiled it in a big lobster pot full of Purple Power
> Degreaser. I did this for about 2 hours (until the degreaser ended up
> eating a hole through the lobster pot). Every 30 mins or so I dumped
> more of the Purple Power down into the muffler as well to make sure
> there was plenty working on the insides. I got this idea from a patient
> of mine (who is a mechanic). He shied away from the idea of putting the
> muffler straight into a burning fire, explaining how that will cause
> microtrauma to the inside of the muffler which would eventually result
> in rust formation from the inside out. I would highly recommend this to
> all attempting to unclog mufflers or remove carbon from engine parts.
That seems a huge over kill , when a dollars worth of oven cleaner or drain opener will do as good or better and not cost you a lobster pot . LOL
Agreed on the direct fire route . I never thought that to be a very good idea .
I have put a fair amount of gas into a muffler and lit it . Had pretty good results from that , but , oven cleaner or drain opener is much safer, cheaper and quicker . (edited)
