Re: 1978 Honda NC50 crankshaft oil seal size
P D /
> Bart Staton Wrote:
> Correct me if I am wrong but its Inside diameter, Outside Diameter, and
> the Height or thickness in Millimeters correct?
That's correct .
The size should be on the flat side of each seal .
If not then , yes measure the shaft , the hole and the depth of the hole .
You might consider 1mm smaller for the ID size of the seal for a tighter fit .
