So I removed the petcock and it looked a bit cruddy. I cleaned it out with carb cleaner but when I try to blow through it only a very small volume of air goes through. If I tried to quantify I would say about the same you could blow through one side of a coffee stirrer.
More details: when I turn it to off then no air passes through, when I turn it the other way no air passes through.
